Did I set myself up for trouble? Mixed collations in db.
Thread begun 2/25/2011 11:59 am by troyd | Last modified 2/25/2011 1:14 pm by Jason Byrnes | 1867 views | 1 replies |
troyd
I created a user registration database from the User Registration Solution and imported the db, which is InnoDB and latin1_. My current tables, which will have recordsets on the same pages are in MyISAM and utf8_.
A couple of my recordsets are using JOINS between them. Everything is working at the moment but as I began to create a couple new tables it accured to me that if there is reason for one or the other, or if I need to convert the older tables, I should do it now.
Neither of my older tables are setup with foreign keys. That was my original intention when I set those up, but now they just use JOINS and WA Manage Relational Tables.
Should I leave well enough alone or should I do something now?
Thanks,
TroyD
this should not cause any issues.
