Two-Column Display on Level Flyout Needed
Thread begun 6/27/2009 8:36 pm by paputxi | Last modified 6/29/2009 9:59 am by paputxi | 2557 views | 2 replies |
paputxi
I created a nice vertical flyout menu using CSS Menu Writer. However, I have a situation where some of the items for a sub-level menu extend beyond the length of the current page (due to limited amount of text in the main body of the page), which results in some of these items not being listed when viewed in a browser since they are off the page.
I can add blank lines as padding at the end of the text, but this results in an odd looking page presentation, which is not the desired approach. The correct resolution I need is to create a two-column display of these menu items at this level.
Is there a way of creating a two-column level flyout using CSS Menu Writer? That would definitely solve the problem I am having here. Thanks in advance.
I'm not quite understanding your description. Do you have a url demonstrating the problem and perhaps a screen shot of the proposed solution? A picture is worth 1000 words.
paputxi
4ray/
In the vertical menu on the left, select Products>Amplifiers and at the third level you will see seven items listed. However, there are actually several more not being displayed since there's not enough text in the main area to allow that. Since I don't want to add more text and adding blank lines as filler space results in a not very pleasant page, I'm thinking a two column list at the third level would provide what I need for these short pages.
Any thoughts would be greatly appreciated. Thanks.
