Multiple update records does not work. Please help
Thread begun 2/24/2011 1:48 pm by danny405167 | Last modified 2/25/2011 12:29 pm by Jason Byrnes | 2929 views | 4 replies |
danny405167
I have been trying to create a simple multi update page but it does not update my records.
I have been reading some threads were people have had the same problem I am having right now. I follow their solution in rearranging the code that gets written in the side the form but no luck. Below is the original code the wizard wrote on my page.
<form action="" method="post">
<table border="1">
<?php do { ?>
<tr>
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_Recordset1){
<td>QTy</td>
<td><input type="hidden" name="WADA_RepeatID_detailsID_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_detailsID_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_Recordset1["detailsID"]; ?>" />
<input name="qty_<?php echo $RepeatSelectionCounter_1; ?>" type="text" id="qty_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_Recordset1['quantity']; ?>" /></td>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<td>No records match your request.</td>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_Recordset1 && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
</tr>
<?php } while ($row_Recordset1 = mysql_fetch_assoc($Recordset1)); ?>
</table>
<input type="submit" name="button" id="button" value="Submit" />
<br />
</form>
please compress the php page into a zip archive and attach the zip file to your post so i can see the entire code in context rather than just the form.
danny405167
Here is the compressed code
I have tried this but no luck
<?php do { ?>
<tr>
</tr>
else{
danny405167
Problem solved
The suggestions that I found on the forums did not work for me. I simply needed to add the key index to my recordset. But I have one question and I hope you can direct me in the right direction.
I need to update the total amount every time I change the quantities. I have unitPrice field, total field which will be updated, and the total field which equals price x quantity.
Example, in my database I have record 1 with unit price =2.00, qty =3, & total =6
When I update the quantity from 3 to 5, the total should automatically be updated in the database to 10. I know that I need to create a hidden field with a value of unitPrice* ?
in this case, I would not store the total in the database at all, i would either calculate the total in the recordsets i create:
SELECT *, FORMAT(price * qty,2) AS total FROM tablename
or i would calcualte it in the php:
<?php echo($row_Recordset1['price'] * $row_Recordset1['qty']); ?>
