DW CS3 Data Assist Sort Object Error
Thread begun 2/24/2011 10:51 am by linda422846 | Last modified 2/24/2011 5:01 pm by Jason Byrnes | 2422 views | 3 replies |
linda422846
I purchased Data Assist for DW this week. So far I'm not very happy - but this could be my own fault.
I'm using DW CS3 with Microsoft Access 2007. I had been using ASP.NET, but since this only works with VB Script, I'm using plain .asp pages now.
Page Name: Index3.asp
Recordset: rsTest
I'm getting the following error after I followed your "Sorting by Column Links" tutorial exactly:
Microsoft VBScript runtime error '800a01a8'
Object required: ''
/Index3.asp, line 50
I realize the object is not being set *somewhere,* but I don't have the coding chops to figure out exactly where.
The problem seems to happen when I set up the "To Add the Sort Server Behavior" in the Data Assist "Sort" dialogue box.
Any help you can offer would be greatly appreciated.
Here is the page code:
<%@LANGUAGE="VBSCRIPT" CODEPAGE="65001"%>
<!--#include virtual="/WADbSearch/HelperVB.asp" -->
' WA QueryString Binding (Copyright 2007, WebAssist.com)
WADA_QSBind_FilteredString = WA_QSBind_QueryString(cStr(Request.QueryString), "sort")
function WA_QSBind_QueryString(tStr, exList)
dim exStr, varStr, n, retCount, thisItem, retTempLen
exList = Split(Replace(cStr(exList), " ", ""), ",")
tStr = Replace(cStr(tStr), "&", "&")
qsArr = Split(tStr, "&")
exStr = ""
varStr = ""
retCount = 0
retTempLen = cInt(UBound(qsArr) + UBound(Split(cStr(Request.Form), "&"))) + 1
ReDim retArr (cInt(UBound(qsArr) + UBound(Split(cStr(Request.Form), "&"))) + 1)
ReDim retVars (UBound(retArr) + 1)
for n=0 to UBound(exList)
exStr = exStr & "§" & exList(n) & "§"
next
for n=0 to UBound(qsArr)
tstArr = Split(qsArr(n), "=")
if (NOT InStr(exStr, "§" & tstArr(0) & "§") > 0) then
retArr(retCount) = qsArr(n)
retVars(retCount) = tstArr(0)
retCount = retCount + 1
varStr = varStr & "§" & tstArr(0) & "§"
end if
next
if (retCount > 0) then
WA_QSBind_QueryString = ""
for x=0 to retCount-1
if(x <> 0 ) then
WA_QSBind_QueryString = WA_QSBind_QueryString & "&" & retArr(x)
else
WA_QSBind_QueryString = WA_QSBind_QueryString & retArr(x)
end if
next
exit function
end if
end function
<!--#include virtual="/Connections/GAE.asp" -->
'WA DataAssist Sort (Copyright 2007, WebAssist.com)
'Recordset: rsTest;
set WADA_Sort_1 = new WADA_SortObject
WADA_Sort_1.init()
WADA_Sort_1.DefaultSort = "LastName"
WADA_Sort_1.ColumnList = "" & cStr(cStr(Request.QueryString("sort"))) & "^" & cStr((rsTest.Fields.Item("LastName").Value)) & ""
WADA_Sort_1.SortOrderList = "Ascending^Ascending"
WADA_Sort_1.ToggleOn = true
if (cStr(cStr(Request.QueryString("sort"))) <> "") then
WADA_Sort_1.SetToClause = WADA_Sort_1.getDefaultSetToClause()
if (WADA_Sort_1.ToggleOn AND cStr(Session("WADA_OrderClause_Index3")) <> "undefined") then
WADA_Sort_1.ToggleClause = Session("WADA_OrderClause_Index3")
end if
elseif (cStr(Session("WADA_OrderClause_Index3")) <> "undefined") then
WADA_Sort_1.SetToClause = Session("WADA_OrderClause_Index3")
end if
WADA_Sort_1.initialize()
Session("WADA_OrderClause_Index3") = WADA_Sort_1.SetToClause
Dim rsTest
Dim rsTest_cmd
Dim rsTest_numRows
Set rsTest_cmd = Server.CreateObject ("ADODB.Command")
rsTest_cmd.ActiveConnection = MM_GAE_STRING
rsTest_cmd.CommandText = "SELECT * FROM CONTACTS"
rsTest_cmd.Prepared = true
setQueryBuilderSource rsTest_cmd, WADA_Sort_1, false
Set rsTest = rsTest_cmd.Execute
rsTest_numRows = 0
Dim Repeat1__numRows
Dim Repeat1__index
Repeat1__numRows = 10
Repeat1__index = 0
rsTest_numRows = rsTest_numRows + Repeat1__numRows
<head>
<link href="/wwwroot/css/basil.css" rel="stylesheet" type="text/css" />
</head>
<body>
<p>The time is now <%= Time %>.</p>
<table width="99%" border="1" cellspacing="0" cellpadding="8">
<tr>
<td>ID</td>
<td>FirstName</td>
<td><a href="/wwwroot/Index3.asp?sort=<%=(rsTest.Fields.Item("LastName").Value)%>">LastName</a></td>
<td>Company</td>
<td>JobTitle</td>
<td>BusinessAddressStreet</td>
<td>BusinessAddressCity</td>
<td>BusinessAddressState/Province</td>
<td>BusinessAddressZip/PostalCode</td>
<td>BusinessAddressCountry</td>
<td>BusinessPhone</td>
<td>Categories</td>
<td>EMAILADDRESS</td>
<td>Notes</td>
<td>ReferredBy</td>
</tr>
While ((Repeat1__numRows <> 0) AND (NOT rsTest.EOF))
<tr>
<td><%=(rsTest.Fields.Item("UNIQUEID").Value)%></td>
<td><%=(rsTest.Fields.Item("FirstName").Value)%></td>
<td><%=(rsTest.Fields.Item("LastName").Value)%></td>
<td><%=(rsTest.Fields.Item("Company").Value)%></td>
<td><%=(rsTest.Fields.Item("JobTitle").Value)%></td>
<td><%=(rsTest.Fields.Item("BusinessAddressStreet").Value)%></td>
<td><%=(rsTest.Fields.Item("BusinessAddressCity").Value)%></td>
<td><%=(rsTest.Fields.Item("BusinessAddressState/Province").Value)%></td>
<td><%=(rsTest.Fields.Item("BusinessAddressZip/PostalCode").Value)%></td>
<td><%=(rsTest.Fields.Item("BusinessAddressCountry").Value)%></td>
<td><%=(rsTest.Fields.Item("BusinessPhone").Value)%></td>
<td><%=(rsTest.Fields.Item("Categories").Value)%></td>
<td><%=(rsTest.Fields.Item("EMAILADDRESS").Value)%></td>
<td><%=(rsTest.Fields.Item("Notes").Value)%></td>
<td><%=(rsTest.Fields.Item("ReferredBy").Value)%></td>
</tr>
Repeat1__index=Repeat1__index+1
Repeat1__numRows=Repeat1__numRows-1
rsTest.MoveNext()
Wend
</table>
</body>
</html>
rsTest.Close()
Set rsTest = Nothing
In addition to adding the sort query string binding to the list of columns to sort, you have added the LastName column from the rsTest recordset.
you cannot use Recordset data in the sort behavior.
linda422846
Solved: DW CS3 Data Assist Sort Object Error
You rock, Jason. Thank you.
My fault, not understanding that. I appreciate the clarification. I might be back to ask about some other stuff in another thread, but that helps immeasurably for now.
Also, my site got farked somehow and there were two wwwroot folders. This was part of the problem.
All fixed and sorting as it should be now.
Thank you again :-)
you're welcome, glad to hear it is working.
