DataAssist: Display Search Result
Thread begun 2/23/2011 11:46 pm by reseller218363 | Last modified 2/24/2011 7:18 am by Jason Byrnes | 1561 views | 1 replies |
reseller218363
Hello.. I need help
I've some issues with the schedule search result page that I'm working on. I want the search results page to display the schedule based on the entry date. and separated by date of entry into the database with divided border line.
please see sample Images:
Image_01 is my sample Image and Image_02 is what I want the display to look like.
Sharach
this is going to require some hand coding to accomplish.
The basic flow of the code will be :
initialize a variable to hold the date, set to to 0
start the do loop
if the date variable is not equal to the date in the current record:
Write the date header
Write the other record information
set the date variable to the date column from the current record
Move to next record
If you are comfortable with writing PHP code, this should not be to difficult.
