Shipping Fee
Thread begun 6/27/2009 1:40 pm by eric284736 | Last modified 6/29/2009 2:26 pm by eric284736 | 2117 views | 2 replies |
eric284736
Shipping Fee
Hi Ray,
To avoid confusion on my part, I started this thread because I have got half of my issue solved.
I am trying to get the shipping charge for local delivery to add to the cart total.
- I have a session that pulls the rate from the table (session: FlowerFee)
- The add to cart button adds FlowerFee from the session and FlowerOrder is added as true if the product is a flower.
Add to cart button code:
<form action="<%=cStr(Request.ServerVariables("SCRIPT_NAME"))%><%=WA_eCart_IIf((Request.ServerVariables("QUERY_STRING") <> ""), "?" & Request.ServerVariables("QUERY_STRING"), "")%>" method="post" id="eCart1_1_ATC_<%=Recordset1.Fields("ItemID").value%>">
<input type="hidden" name="eCart1_1_FlowerFee_Add" value="<%= Session("FlowerFee") %>" >
<input type="image" src="WA_eCart/Images/Pacifica/Btn2_EN_addtocart2.gif" border="0" value="Add to Cart" name="eCart1_1_ATC">
<input type="hidden" name="eCart1_1_Weight_Add" value="0" />
<input type="hidden" name="eCart1_1_FlowerOrder_Add" value="true" />
<input type="hidden" name="eCart1_1_ID_Add" value="<%=Recordset1.Fields("ItemID").value%>" />
<input type="hidden" name="eCart1_1_Name_Add" value="<%=(Recordset1.Fields.Item("ItemName").Value)%>" />
<input type="hidden" name="eCart1_1_Quantity_Add" value="1" />
<input type="hidden" name="eCart1_1_Price_Add" value="<%=(Recordset1.Fields.Item("ItemPrice").Value)%>" />
</form>
We have the UPS shipping charge in place and that works correctly and I have the Flowercharge setup under Shipping as you can see in the attachment. But that is not working. I am not sure what calculation method I should be using to pull the fee from the session.
thanks,
Eric
Trigger:
Total of FlowerFee column > 0
Amount:
Total of FlowerFee
eric284736
Thanks!!!!!!!
That works. And much simpler than I was making it :)
