Problem with ecart object panel
Thread begun 2/23/2011 6:27 am by jpmtyrrell415278 | Last modified 2/23/2011 12:49 pm by Jason Byrnes | 2041 views | 3 replies |
jpmtyrrell415278
Hi i purchased the webassist super suite today. I am using dreamweaver cs3 I am trying to use the ecart function for my site,i have selected a php page,and inserted the serial all correct.But when i go to the object panel it stays locked.Can you please help me.....
What is the build number of the Dreamweaver version you have installed?
Go to Help -> About Dreamweaver.
Click the about dialog box once to force it to scroll to the end, the Version and build number will be listed here.
The build number should be build 3481 or above. If you have an earlier build, you can try installing the Dreamweaver CS3 update available from Adobe at:
downloads_updaters.html#dw9
jpmtyrrell415278
Hey
yeah it is version 9.0 3481.For some reason when i select the ecart option the top pane is greyed out so is the edit button.I have set up and defined my site and made a php page.But still no luck i reinstalled the plug ,but still no luck?Can you give me a solution?please
is the php page saved to your site?
The php page must be saved to the site before proceeding.
If you are still having a problem, try installing the update from the link in my previous post.
if that does not correct the issue, please send screen shoots of your site definition settings and a screen shot showing the problem
