SQL errors
Two errors:
1. In PowerStore, confirm.php, line 512.
$WA_indexField = "DetailOrderID";
should be: $WA_indexField = "DetailID";
2. Using the checkout wizard with eCart, paypal standard selected, I would think that the save to database should overlay the PowerStore schema.
a. $WA_fieldNamesStr = "OrderShipping|OrderTax|OrderTotal";
OrderTotal is not a field in the schema as defined in PowerStore. OrderAmount is probably the intended field but.....who knows without any comments in the schema.
b. $WA_indexField = "DetailsID"; is the generated code while it
While #2 is technically not a bug, it should be changed if for no other reason than maintainability by Webassist. It would also help the user.
