Favicon
Thread begun 2/22/2011 12:57 am by sunsabbath76401977 | Last modified 5/24/2011 6:37 am by Jason Byrnes | 3911 views | 6 replies |
sunsabbath76401977Beta Tester
Favicon
Hi, how do I add a favicon to a site?
Favicon
Thanks for reading Sabby76
DarylBeta Tester
This site might help a little better http://www.favicon.co.uk/
Favicon
Thank you Daryl
The information you provided worked out!
I found favicon/
dynamcidrive worked better for me using a vista pc with CS4 dreamweaver.
For anyone reading this post with a view to having ago at implementing a favicon, use the dynamicdrive html code: <link rel=”shortcut icon” href=”favicon.ico”> its simpler and worked for me incomparison to other online freebees. I was not able to test locally which is my fault. Try and download the generated dynamicdrive favicon.ico file to individual pre-paired folders in the downloads folder, the ico file is a bit live a carries information over to replacement .ico's. Testing meant that a 454 x 340 PNG 8 jams into resolution for the downscale size 16 x 16 pixels with-out carring the alpha channel, I had to use a PNG instead of a Jpeg or GIF as they show a grey scale placed over the browser alpha channel giving a dirty appearence. Finally Voila!
www.pizzapal.co.uk
Thank you for reading
Sabby76
ripair417048
Adding Favicon
Which file do you add the code:
to make it show up for entire site and all pages?
mglc83
super easy
Hi there,
The steps for favicon is very simple:
1: generate a favicon- easy to do for free just google it.
2: download onto your computer.
3: open your dreamweaver site that you desire the favicon to be on
4: Go to INSERT/HTML/HEADTAG/LINK
5: Browse for your favicon file, under REL put ICON hit ok
6: Save and upload to your server and your done!
5 minute process!
mglc83
Originally Said By: RIPAIR
If your pages are connected through a template, adding the icon to the main template page save it and it will populate all pages... if you are not linked to a template on all pages you may have to insert each page-
is there any easier way??
if the site is not based on a template, the only way to add the facvicon to every page in the site is to manually add the:
code to each page.
could maybe do it using Dreamweaver Search and Replace. Search for the :
<head>
tag and replace it with:
<head>
