Setting up Discounts using Coupons in ecart
Thread begun 2/21/2011 2:10 pm by Nature Photographer | Last modified 3/01/2011 2:13 pm by Nature Photographer | 8195 views | 10 replies |
Nature Photographer
I'm not overly knowledgable when it comes to web development so any help would be appreciated.
I am using ecart 5.03 and want to set up a discount on purchases using a "coupon" or something simular so that only people that know the coupon get the discount.
How would I set this up? The shopping cart process is otherwise all setup and functioning just need to apply this discount to the products.
Thanks in advance!
In the archived documentation section of the eCart support page:
ecart/
there is a tutorial titled "Creating a Coupon system for your eCart store It was created for eCart 4, but is still relevant for eCart 5, the steps will be exactly the same.
Nature Photographer
Thanks Jason
Hi Jason,
That worked like a treat! :-)
I have a couple more quick questions;
How do I now set this coupon only to work during a set period of time, say March 2011?
also
How do I have a message display saying the entered code is not valid?
Thanks again Jason
In the trigger for the discount, add 2 triggers:
If today is after a certain day:
2/28/2011
AND
If today is before a certain day:
4/1/2011
to show an error if the entered coupon code does not match the one in your discount rule, add another set session value behavior on the cart page, set the trigger to Before page load, set the name to something like realCode and set the value to the same value used in the discount rule.
then add an if statement to compare the two:
<?php if(isset($_SESSION['PromoCode']) && isset($_SESSION['realCode']) && ($_SESSION['PromoCode'] != $_SESSION['realCode'])) { ?>
the promo code entered did not match
<?php ?>
Nature Photographer
More assistance needed please
Hi again Jason,
Thanks for all the assistance to date.
I got the first part of your advice to work eg the date of coupon being valid, I don't fully understand the part about creating the secound part.
Where do I put the PHP code you provided and I tried setting the session value behavior on the cart page but not sure if I'm setting it up right as it doesn't seem to work for me.
The "input" coupon word that they have to put in is MGPS, do I put this in the "real code" part you gave?
bookingcart.php
is the page I am trying to set this up on, if that helps.
if the coupon code in the discount rule "MGPS", then set the "realCode" session variable value to ""MGPS" the trigger for the set session value behavior for the realCode session variable should be Before Page load.
if you are having trouble, send me a copy of the page in a zip archive so I can see the code.
Nature Photographer
Page attached
Thanks Jason
I've attached the page as requested...hope this helps
I dont see where you have added the ifg statement to show the error:
<?php ?>
you dont seam to have this code on your page, add this code where you would like to display the error.
Nature Photographer
Still can't get it to work
Jason, I do thank you for your assistance but I still can't get it to work...I said I wasn't a web developer/designer so saying "put this code on the page" doesn't really help me to know where I am putting it. I might be dumb but when told I will remember.
I've included the page again with where I think you meant the code to go (probably I am wrong) but it doesn't work for me...I got an error "Notice: Undefined index: PromoCode in C:\xampp\htdocs\jamesdoylephoto\Bookings\bookingcart.php on line 17" at one stage so I moved the code to a different location and now nothing happens when the wrong coupon is entered.
I did clarify where the code should go by saying:
I cont tell you exactly where the code should go in your page, it needs to be in the place of your page where you want the error to be displayed.
in design view, place your cursor where the error should go, the switch to code view and paste the code in.
you have changed the code for setting the real code session variable to use the value pf the promo code session:
if("" == "") {
$_SESSION["RealCode"] = "".$_SESSION['PromoCode'] ."";
it should be using the hard coded value MGPS:
if("" == "") {
$_SESSION["RealCode"] = "MGPS";
