Initialize Error
Thread begun 6/27/2009 6:32 am by wda237270 | Last modified 9/11/2009 1:15 pm by Dani Chankhour | 4092 views | 4 replies |
wda237270
Initialize Error
This is the first time using the latest version of CSS Sculptor. Afte installing the extension and trying to use the app I get an error.
While executing onLoad in wacs_wizard.htm, the following JavaScript error(s) occured:
In file "wacs_wizard";
InitializeUI is not defined
The first time it occured I uninstalled the extension and reinstalled it. I had the same results after the reload. Any ideas? Thanks!
russell355191Beta Tester
fix
you'll need to delete the macfilecache.dat file.
Make sure DW is closed before you delete it.
Then boot DW back up, you will need to put your serial number back in.
On a mac you find it in this folder
Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US: Configuration
Regards
Russ
wda237270
Initialize Error
Thank You! I should have mentioned that I was on Windows, but your answer got me to the correct file and deleted it and was able activate the extension. Thanks again!
Jackyboy
Javascript error on launch of CSS Sculptor 2.0.5
I have read these posts, followed the instructions, but still have the same problem. I am on OSX 10.4.11 and DW CS3.
I also uninstalled CSS Sculptor and tried reinstalling it. Now what?
Thanks!
Jack
Dani Chankhour
I would recommend deleting your configuration folder and reinstalling the extension. Please read this post on how to delete your configuration folder:
showpost.php?p=15525&postcount=2
Let me know if you still have the issue.
