file manager on update page
Thread begun 2/21/2011 9:01 am by this_is_me | Last modified 2/22/2011 12:07 pm by Jason Byrnes | 1646 views | 1 replies |
this_is_me
what would be the best way to delete a picture (file) on an update page? On the update page I see the already inserted picture but I see no possibility to delete a picture. If I delete it on the server, it will tell me "select a file" and if I cancel, the name of the old picture remains in the field...
I cannot delete this entry of the file manager field.
make sure that the update record behavior applied to the page is set to trigger on the Forms submit button.
add another button next to the image form element, name it deleteImage, set the value to return the file name value from the recordset
Add a file manipulation - > Delete file behavior.
set the trigger to use the Button deleteImage pressed
set the path to use the same path as the file manager, set the file name to use the deleteImage button value.
add another update record behavior, this one will use the deleteImage trigger again, set the value for image column to a blank space, so that it will be the only column updated.
