Administrator Access
Thread begun 2/21/2011 8:42 am by robert329616 | Last modified 2/24/2011 6:56 am by Jason Byrnes | 2260 views | 3 replies |
robert329616
Hello.
I want to give access to my client for looking at revenue charts and to send out the shipping confirmation emails. I checked the help section of the store manager section to see how I could do this.
When I select add user I run into an issue when I go to select the access group, there are no options to select in the access group drop down menu. Should this be part of the store manager or something I have to set up. If I have to set it up, is there a tutorial or a thread to walk me through this?
Thanks.
Rob
what version of power store?
if this is power store 4, the power soter database should have a ps4_usergroups table, double check that the ps4_usergroups table exists, if not, run the following query:
CREATE TABLE IF NOT EXISTS `ps4_usergroups` (
`UserGroupID` int(11) NOT NULL auto_increment,
`UserGroup` varchar(50) default NULL,
PRIMARY KEY (`UserGroupID`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8;
/*Data for the table `usergroups` */
insert into `ps4_usergroups`(`UserGroupID`,`UserGroup`) values (1,'User');
insert into `ps4_usergroups`(`UserGroupID`,`UserGroup`) values (2,'Administrator');
robert329616
Jason,
It was ps4 and there was a usersgroup table, it wasn't populated. It works perfectly after I ran the query, thanks!
Rob
Ok, glad to hear it is working.
