Upload file permissions cannot be changed for thumbnail image on upload
Thread begun 2/20/2011 9:41 am by Thomas Hill | Last modified 3/01/2011 11:50 am by Jason Byrnes | 6496 views | 12 replies |
Thomas Hill
I've used the upload server behaviour in UE 4 to upload an image field and create a thumbnail but have been having difficulty with the file permissions.
I've followed the threads that explain to change the code from:
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "image_upload", "2", "[ExistingFileName]_[Increment]", "false", $WA_UploadResult1_Params);
To:
chmod($WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]."".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"], 0644);
This works great and changes the permission for the first image but not the second thumbnail image.
For now, the work around I am using is to have two separate server behaviours and two upload file fields but I really do want to be able to do this as I have another page I wish to implement this on.
Hope you can help.
change:
chmod($WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_2"]["serverDirectory"]."".$WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_2"]["serverFileName"], 0644);
Thomas Hill
Thank you
Cheers dude!
Worked perfectly! :-)
excellent, glad to hear it is working.
Thomas Hill
Now get an error if user leaves upload field blank
I am now getting the following error if the user leaves the field blank on submitted the form (even if they is already an uploaded photo).
My guess is to populate a form element and use this as the default file part but I can't get it to work. Can you help please?
Warning: chmod() [function.chmod]: No such file or directory in /users/thomas740/www.thomash.co.uk/testing/users_Profile_edit.php on line 127
Warning: chmod() [function.chmod]: No such file or directory in /users/thomas740/www.thomash.co.uk/testing/users_Profile_edit.php on line 128
Warning: Cannot modify header information - headers already sent by (output started at /users/thomas740/www.thomash.co.uk/testing/users_Profile_edit.php:127) in /users/thomas740/www.thomash.co.uk/testing/users_Profile_edit.php on line 186
send me a copy of your page so i can see what you have set up so far.
Thomas Hill
Files
The user_profile_edit page includes the upload/edit info.
you have set the default file options to use recordset values.
create hidden form elements and set the hidden form elements to use the recordset data as the initial value. Then in the default file section, use the hidden form elements.
Thomas Hill
Still no good
I forgot to mention that I'd already tried it that way but still had the same error. However if I add the folder info before it then it works BUT this info is then stored in the database as folder/folder/filename.jpg
Naturally this won't then work when the user comes to change details and leaves the field blank a second time.
I've included the file for you to look at again.
Tom
i'd need to see the file where you didn't include the folder names to tell why that was not working.
to remove the folder names from the current version, edit lines 104:
'DefaultFileName' => "images/profile_images/".((isset($_POST["existing_image"]))?$_POST["existing_image"]:"")  ."",
and 114:
'DefaultFileName' => "images/profile_images/".((isset($_POST["existing_thumb_image"]))?$_POST["existing_thumb_image"]:"")  ."",
104:
'DefaultFileName' => "".((isset($_POST["existing_image"]))?$_POST["existing_image"]:"")  ."",
and 114:
'DefaultFileName' => "".((isset($_POST["existing_thumb_image"]))?$_POST["existing_thumb_image"]:"")  ."",
