Error after upgrading Site Sculpter with Power CMS 2.10
Thread begun 2/18/2011 2:21 pm by Larry | Last modified 3/02/2011 8:50 am by Jason Byrnes | 6478 views | 13 replies |
Larry
After upgrading Site Sculptors CMS to Power CMS 2.10, and following the the instructions here http://www.webassist.com/support/site-sculptor/how-tos/upgrading-ss-powercms.php, I now get the below errors and can go no further.
Warning: require_once(../webassist/framework/library.php) [function.require-once]: failed to open stream: No such file or directory in C:\wamp\www\Test\admin_cms\index.php on line 2
Fatal error: require_once() [function.require]: Failed opening required '../webassist/framework/library.php' (include_path='.;C:\php5\pear') in C:\wamp\www\Test\admin_cms\index.php on line 2
Any and all help would be greatly appreciated.
Larry
In the Power Cms Files, there isa a folder called "webassist" this folder needs to be copied to the site sculptor site root.
StephenMartin
I followed the instructions. Even uploaded the webassit file and got this error:
Fatal error: Cannot redeclare rel2abs() (previously declared in /home/content/s/t/e/stephenmartin/html/willempat/webassist/framework/library.php:19) in /home/content/s/t/e/stephenmartin/html/willempat/WA_CMS/library.php on line 21
Do you know what's going on here?
Larry
I received the same error message after trying Jasons recommendation. I just decided to move on to working on something different for awhile.
But I would also be interested in the solution.
Larry
StephenMartin
Originally Said By: Larry
Larry
I was wondering if his solution worked for you. I've moved on as well. But I do hope someone will chime in with an answer. That would be great.
Larry
Hi StephenMartin,
After trying Jason's suggestion about moving the "webassist" folder, I also then received the same fatal error as you
I then just moved on, but I am also looking for a solution.
Larry
here is an updated copy of the library.php file that will correct the problem.
copy it to the webassist/framework/library.php and WA_CMS/library.php locations.
StephenMartin
Worked like a charm, Jason! Thanks so much for the promt reply and the help. Much appreciated!
Larry
Thank you Jason,
This did seem to fix the problem. I would however like to point out that I did not have the "webassist/framework/library.php" location, but I did change the library.php in the "WA_CMS/library.php" location.
So, for now the site is not showing any errors and it seems to be working correctly.
Thank you
Larry
StephenMartin
  Thank you Jason,
Larry
Same here.
