HTML Editor 3
Thread begun 2/18/2011 8:26 am by solasweb104077 | Last modified 2/18/2011 11:21 am by Jason Byrnes | 4403 views | 7 replies |
solasweb104077
HTML Editor 3
Hi, when I add 2 editors to the same page by default they are called "editorField" and "editorField2" which is fine but when I add an insert record in DW the only form option I have available is "editorField2"
See image here: 36122980.jpg/
How do I add more than one instance of the editor?
I get a server not found error trying to follow your link
can you send a copy of your page in a zip archive so i can see the code.
solasweb104077
What address can I send that page too?
attach the zip archive to your message here in the forum
solasweb104077
file attached now
I have logged this as a bug to be corrected in the net update to HTML editor, it should be released soon. in the mean time, you will need to edit the insert record code after it is applied>
if you need guidance on what to edit, send a copy of the page after the insert record is applied and I will let you know the line number.
solasweb104077
Thanks for looking Jason, will give that a go
you're welcome.
