search and existing sql WHERE clause
Thread begun 2/18/2011 7:29 am by mark336119 | Last modified 2/18/2011 11:46 am by Jason Byrnes | 5772 views | 11 replies |
mark336119
I have a search setup and working. I was hoping to limit the results simply by using a WHERE in the database sql.
ie. SELECT * FROM content WHERE pagecategory = ?
However, existing WHERE clauses in the sql are ignored by DA search (cannot exclude anything from the search pool).
Is there something I need to be aware of here, or I am missing?
Add it as a criteria to the data assist search behavior so it will be included in the where clause that data assist search creates.
mark336119
Had tried that, but couldn't get that to return properly either:
WADbSearch3_whereClause=BuildFilterString("pagecategory","do_not_show_on_menu","AND NOT","Includes",0,WADbSearch3_wildCard,WADbSearch3_dateSeparator,WADbSearch3_whereClause)
it looks like the criteria you are using is AND NOT Includes do_not_show_on_menu
from the SQL example, it looks you should be using
AND Equals do_not_show_on_menu
mark336119
sorry, the original sql was an exclude (SELECT * FROM content WHERE pagecategory <> ?). I was just trying a few options to see if I could include/exclude anything at all.
problem is, none of the filters in the DA criteria seem to factor (excluding or including). My limits were simple... so was just going to do that in the sql, but that is ignored as well.
the <> operator is NOT EQUALS, send a copy of your page so i can see the entire code to offer debugging advice.
mark336119
again, trying to exclude certain pages from showing in the search results.
searching works fine, but cannot exclude anything. Tried in the sql statement, and with DA filters. thanks.
<%' PAGES SEARCH *********************************************%>
dim WADbSearch3_DefaultWhere
WADbSearch3_DefaultWhere = ""
if (cStr(Request.Form("WADbSearch1")) <> "") then
dim WADbSearch3_whereClause, WADbSearch3_dateSeparator, WADbSearch3_wildCard
WADbSearch3_wildCard = "%"
WADbSearch3_dateSeparator = "'"
if ("ACCESS" = "ACCESS") then
WADbSearch3_dateSeparator="#"
end if
if ("ACCESS" = "ORACLE") then
WADbSearch3_dateSeparator="TO_DATE('"
end if
if ("ACCESS" = "MYSQL") then
WADbSearch3_dateSeparator="MYSQL"""
end if
'keyword array declarations
Dim WADbSearch3_KeyArr0, WADbSearch3_KeyArr1, WADbSearch3_KeyArr2, WADbSearch3_KeyArr3
WADbSearch3_KeyArr0 = Array("pagecategory")
WADbSearch3_KeyArr1 = Array("pagesection")
WADbSearch3_KeyArr2 = Array("cont_cnt")
WADbSearch3_KeyArr3 = Array("subsection")
' added by mark, remove spaces which disable searchability
Dim searchphrase_pages
searchphrase_pages = RTRIM(cStr(Request.Form("search")))
'comparison list additions
WADbSearch3_whereClause=BuildKeyword(WADbSearch3_KeyArr0,"" & searchphrase_pages & "","OR","Includes",",%20","%20","%22","%22",0,WADbSearch3_wildCard,WADbSearch3_dateSeparator,WADbSearch3_whereClause)
WADbSearch3_whereClause=BuildKeyword(WADbSearch3_KeyArr1,"" & searchphrase_pages & "","OR","Includes",",%20","%20","%22","%22",0,WADbSearch3_wildCard,WADbSearch3_dateSeparator,WADbSearch3_whereClause)
WADbSearch3_whereClause=BuildKeyword(WADbSearch3_KeyArr2,"" & searchphrase_pages & "","OR","Includes",",%20","%20","%22","%22",0,WADbSearch3_wildCard,WADbSearch3_dateSeparator,WADbSearch3_whereClause)
WADbSearch3_whereClause=BuildKeyword(WADbSearch3_KeyArr3,"" & searchphrase_pages & "","OR","Includes",",%20","%20","%22","%22",0,WADbSearch3_wildCard,WADbSearch3_dateSeparator,WADbSearch3_whereClause)
'WADbSearch3_whereClause=BuildFilterString("siteside","" & cStr( Session("siteside") ) & "","AND","Includes",0,WADbSearch3_wildCard,WADbSearch3_dateSeparator,WADbSearch3_whereClause)
if (1 = 1) then
Session("WADbSearch3_search")=WADbSearch3_whereClause
end if
else
if (1 = 1) then
if (cStr(Session("WADbSearch3_search")) <> "") then
WADbSearch3_whereClause = cStr(Session("WADbSearch3_search"))
else
WADbSearch3_whereClause = WADbSearch3_DefaultWhere
end if
else
end if
end if
Dim searchresults_pages__MMColParam
searchresults_pages__MMColParam = "do_not_show_on_menu"
If (Request("MM_EmptyValue") <> "") Then
searchresults_pages__MMColParam = Request("MM_EmptyValue")
End If
Dim searchresults_pages_cmd
Dim searchresults_pages_numRows
Set searchresults_pages_cmd = Server.CreateObject ("ADODB.Command")
searchresults_pages_cmd.ActiveConnection = MM_khtml_STRING
searchresults_pages_cmd.CommandText = "SELECT * FROM content_cnt WHERE pagecategory <> ?"
searchresults_pages_cmd.Prepared = true
searchresults_pages_cmd.Parameters.Append searchresults_pages_cmd.CreateParameter("param1", 200, 1, 50, searchresults_pages__MMColParam) ' adVarChar
setQueryBuilderSource searchresults_pages_cmd, WADbSearch3_whereClause, false
Set searchresults_pages = searchresults_pages_cmd.Execute
searchresults_pages_numRows = 0
<% ' END PAGES Search *****************************%>
to see the sql that is being generated, add the following code after the <body> tag:
SQL: <%=searchresults_pages_cmd.CommandText %>
post the results back please.
mark336119
here it is...
SELECT * FROM content_cnt WHERE pagecategory <> ? AND ((pagecategory LIKE '%contact%')) OR ((pagesection LIKE '%contact%')) OR ((cont_cnt LIKE '%contact%')) OR ((subsection LIKE '%contact%')) AND NOT (pagecategory LIKE '%do_not_show_on_menu%')
well, it is adding both of the conditions to the where clause, your initial where clause is not being ignored, it is being added in.
this section:
is initial where clause, and this one:
is the new criteria that you added. Is "do_not_show_on_menu" the actual value that is stored in that column?
