How can I delete ALL cookies with Security Assist?
Thread begun 2/17/2011 8:02 am by sandy170299 | Last modified 2/17/2011 1:06 pm by Jason Byrnes | 4898 views | 3 replies |
sandy170299
I have a client who does not want autologin or remember me enabled at all. Unfortunately, this has already been initiated. How can I now get rid of these cookies? users_LogOut.php is not deleting them. Thank you!
if you want to remove the auto login functionality, you will just need to delete the second Authenticate user behavior that is applied to the login page.
Look in the server behaviors panel for the login page, you will see that there are t 2 security assist Authenticate User Behaviors, Double click each one and look at the triggers. One is using a form submit trigger, the other is using the cookies as a trigger.
Delete the one that uses the cookies as the trigger to remove the auto login function.
sandy170299
Thanks, Jason. looks like that did the trick. I also just deleted everything referencing a cookie - just to make sure :)
Ok, glad to hear it is working.
sandy170299
Jason, I have an addendum to this post. I needed to change a master user name and password in the database, so now my user isn't recognized any longer. Each time I log in, it keeps taking me back to the login page, even though I am using the new login info in the database. How can I work around this issue? Thanks!
sandy170299
p.s. I had auto login and remember me both checked. I'm sure this is causing the problem.
yeah, having those enabled would remember the old User name and password
sandy170299
So what code do I use to delete those cookies so I can start from scratch? Thanks!
clear your browsers cache, that will remove the cookies
sandy170299
Actually, that didn't work. I did it twice, closed my browser and restarted it, but it's not removing the cookies. Should I post the file?
