PS3 DB Queries taking too long
Thread begun 2/16/2011 4:49 pm by avatar8390144 | Last modified 2/19/2011 7:50 am by hmyrick308645 | 4252 views | 6 replies |
avatar8390144
We're experiencing some very long DB query times on our PS3 site, and it's slowing the site down considerably. In looking at the mysql_slow_queries log files, some queries are taking over 6 seconds to complete (!!).
We've checked with the host (Bluehost) and they've confirmed that others on the same shared server are not experiencing the same problem. Would there be something about PS3 or our store that would be causing this?
The site is www.boomco.com
Try clicking on one of the items in the product menu.
Using PHPMyAdmin or another MySQL Administrative tool, try running the following queries on the ps3 database:
ALTER TABLE ps3_productcategories ADD KEY `ProductID` (`ProductID`);
ALTER TABLE ps3_productoptions ADD KEY `ProductID` (`ProductID`);
avatar8390144
Running those queries had an immediate effect in speeding up the site. What exactly did those queries do? I'm assuming they refined the DB somehow?
Will I need to run these again, or is this a permanent change?
Thanks.
they add an index the productID columns of the ps3_productcategories and ps3_productoptions tables.
Those two columns create the relations to the products table. Adding an index to relational columns makes it easier for the database to perform queries where it needs to get data from both tables.
you should not need to run the queries again, once the index is created, it is a permanent change.
hmyrick308645
Was having the same problem ...
I am working on a PS4 site with about 350+ products, most of which have 5-8 advanced options. It was excruciatingly slow to retrieve a list of products. I ran these queries (changing the table names for PS4) and the speed was improved dramatically. This should probably be posted as a known issue for sites with a lot of products that have many advanced options.
Was your store an update from power store 3? We did add the indexes in power store 4 on new installs, but it may not create the indexes on updates.
hmyrick308645
Not an update
No, it was a new install. One of the indexes may have been in place but the other query was executed successfully and the speed was instantly improved.
