Insert Record loop error
Thread begun 2/16/2011 11:14 am by fdotmedia | Last modified 2/16/2011 2:01 pm by Jason Byrnes | 2046 views | 3 replies |
fdotmedia
My current task is to pull data from a "Results" table that stores one row of data from a form submission and populate a table of "Responses," for example ResultsID 15 would have an entry for Result1, Result2, Result3 and so on (up to 30). I'm taking that data and for every Result# I'm putting it into it's own Response row. So the Result1, Result2, Result3 from ResultsID 15 would now be ResponseIDs 24,25, and 26. (Numbers here are arbitrary).
In the code, I'm trying to do a loop - updating $i whenever it runs through the code. So in theory, I should only come up with 30 new Response rows - but what's happening is I'm returning an infinite number of Response rows that are filled with Result1.
Any idea what's going wrong?
<?php $i = 1; ?>
<?php $result = 'Result';?>
// This code inputs the data from the Results table into the Response table, for as many "ResultX" are in the Results table.
if ("" == "") // Trigger
$WA_connection = $surveys;
$WA_table = "Response";
$WA_sessionName = "Response_ReID";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "ReID";
$WA_fieldNamesStr = "ReOrder|UtID|TTID|PID|Response";
$WA_fieldValuesStr = "$i" . "|" . "".$row_resultrow['UtID'] ."" . "|" . "".$row_resultrow['TTID'] ."" . "|" . "".$row_resultrow['PID'] ."" . "|" . "".$row_resultrow["$result$i"] ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|none,none,NULL|none,none,NULL|',none,''";
$WA_connectionDB = $database_surveys;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
$i = $i + 1;
} while ($i <= 30) ?>
your code to increment it value of $i is in an if statement that will only evaluate to true if there is a redirect URL, which there isn't.
move the increment code so it is just before the while statement.
fdotmedia
Awesome, thanks Jason.
you're welcome.
