PowerStore Beta Build 054 Available
Thread begun 2/16/2011 11:01 am by Anna Robinson | Last modified 2/22/2011 9:29 am by Dave Buchholz | 3182 views | 6 replies |
Anna Robinson
Build 054 is ready for beta testing. This build includes fixes for the issues Dave reported this week.
Dave, We'd greatly appreciate if you could do a fresh install and run the same scenarios.
Anyone else can test with this build as well. Here are the details:
Download PowerStore beta build 054
Serial #: hPSYG-DptnI-0yEzA-uCZKi
Dave BuchholzBeta Tester
Anna,
I'll download and test today
The checkout page still doesn't automatically call the SSL cert, go here products_results.php add anything to the cart and checkout and it still calls checkout.php NOT checkout.php as it should when entering credit card details
Stopped at that point as I do not want to enter my CC details again over an unsecured connection.
You can always update the http:// to https:// manually in order to continue with the checkout process.
That url must be wrong or maybe only viewable locally for you. Is the https certificate installed and functioning properly on that test site? We just installed a cirtificate on our dev server to better test that it redirects properly, so we'll make sure to get it adjusted, but it would be helpful if you tested the rest of the process so we could incorporate any other suggestions you might have.
Agreed but not everyone who purchases Powerstore will have the "expertise" to do this and I believe this needs to work out of the box
The site is on my main server in a subdomain, you are welcome to try the site for yourself if you doubt what I am telling you. I have a wildcard SSL cert installed on the server specifically for this kind of testing if you visit powerstore.i-cre8.com/ you will see the certificate is working.
OK I found the issue. We'll try to get a new build out today to resolve it. Thank you for your patience.
Great, thanks Ray
