upload stopped working?
Thread begun 2/16/2011 2:38 am by henk303241 | Last modified 2/17/2011 11:42 am by Jason Byrnes | 3977 views | 7 replies |
henk303241
On a website I have a file with the insert record behavior en file upload (data assist / universal email). Everthing worked fine until monday. Suddenly it stopped working. Files aren't uploaded anymore and the record isn't put in the database. Seems like the page hangs in the browser. It's driving me nuts!
Any suggestions?
The server has space enough and the upload directory is writable (777).
Errorlog: [error] [client IPADRES] File does not exist: /usr/home/SITE/public_html/CLIENT/imginh/thumb_, referer: afbeeldingen.php?id_inh=10
Some additional information:
- without the file upload, the data is stored in the db correctly
- with the upload the data is stored in de DB, but the filefield is blank
- I made a new upload.php with just a file upload behavior and the file isn't uploaded, no error logs on the server
to trouble shoot the problem, edit the Insert record behavior and set it so it will not redirect to another page.
then, add the following code at line 1:
error_reporting
(E_ALL);
then on the bindings panel, expand the the WA Uploaded Files Global Status binding group and add the debug info binding to the page.
Post back with the debug info, any errors that are displayed and a copy of the page in a zip archive.
henk303241
Here is the zip file.
ok, but after running the upload, where there any errors? and what did the debug binding show?
henk303241
This is the page I used for debugging, maybe I didn't do the binding correct?
The data is stored in de DB, except for the filename en the file isn't uploaded.
If you want I can send you the url and grant you access to the site.
the bindings are applied to the page just fine.
What I am asking is:
When you try to upload a file after applying these pages, Are there any errors displayed on the page?
Also, you added the debug info at the bottom, what is the output of the debug info?
henk303241
The error txt was in the first zip
