.dat file attachments
Thread begun 2/15/2011 2:41 pm by lbunnell124698 | Last modified 2/24/2011 9:18 am by Jason Byrnes | 3767 views | 5 replies |
lbunnell124698
I'm using Universal Email and the file is sending but the attachments are all being delivered as .dat files instead of .pdf files.
This sends unopenable .dat files:
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".$row_rsForms["attach_frm"] ."");
where $row_rsForms["attach_frm"] is a PDF file from the same directory level as the script that calls the Universal Email function. (i.e forms/somefile.pdf)
This sends no attachments:
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"/home/xxxx/public_html/PDF/".$row_rsForms["attach_frm"] ."");
Using Universal Email 3.0.7
an you send a copy of your WA_UniversalEmail/mail_php.php page please.
lbunnell124698
Here you go...
try changing lines 235 - 253:
if(sizeof($mailObj->attachments) > 0)    {
    foreach ($mailObj->attachments as $fileArr)    {
      if (is_readable($fileArr[3]))    {
        if (strtolower($fileArr[1]) == "base64")     {
          $data = chunk_split(base64_encode(implode("", file($fileArr[3]))));
        else     {
          $data = implode("", file($fileArr[3]));
        $mailAttachments .= $lineEnd."--WAMULTIBREAKWA";
        $mailAttachments .= $lineEnd."Content-Type: ".$fileArr[0];
        $mailAttachments .= "; name=\"".basename($fileArr[3])."\"".$lineEnd;
        $mailAttachments .= "Content-Transfer-Encoding: ".$fileArr[1].$lineEnd;
        $mailAttachments .= "Content-Disposition: inline;";
        $mailAttachments .= " filename=\"".basename($fileArr[3])."\"".$lineEnd.$lineEnd;
        $mailAttachments .= $data;
            else     {
            if ($fileArr[2] != "")  {
                $mailAttachments .= "; name=\"".basename($fileArr[2])."\"".$lineEnd;
            else  {
                $mailAttachments .= " filename=\"".basename($fileArr[2])."\"".$lineEnd.$lineEnd;
            else  {
lbunnell124698
That didn't seem to make any difference. The .pdf files are still being sent as .dat files
Any other suggestions?
