insert with no recordset
Thread begun 2/15/2011 9:17 am by davidp420108 | Last modified 2/16/2011 12:57 pm by Jason Byrnes | 6066 views | 11 replies |
davidp420108
i am confused on how the insert works in datassist. there is no recordset defined (at least not showing in the DW behaviors screen).
My structure is a dealer_tbl with a joined table called inventory_tbl ( i think it is a left joined but not sure).
I want to insert a new record into the inventory_table but i need some data from the dealer_tbl. If i were making a recordset, i would join them and it is easy enough. but i dont understand the DA insert record. do i just make a recordset and insert to it, or do i need to create a session variable when they log in? or can i modify the following code to be a JOIN?
be prepared for me to ask a couple of follow up questions :)
thanks
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $Auto_Sales;
$WA_table = "inventory_tbl";
$WA_sessionName = "WADA_Insert_inventory_tbl";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "Inventory_ID";
$WA_fieldNamesStr = "Dealer_Name|Price|Make|Model|Year|Engine|Drivetrain|Transmission|Mileage|Ext_Color|Int_Color|Body_Style|VIN|Stock_Number|Description|Date_Online|Expires|pwr_windows|pwr_locks|rear_slider|DVD|3rd_seat|premium_sound|leather|bed_liner|premium_wheels|Dealer_TBL_Dealer_ID|Status|City|Contact_Phone";
Dave BuchholzBeta Tester
The DA Insert Record Server Behaviour would normally be used in conjunction with a form that posts it's contents to the page the Server Behaviour is on, so typically in an admin section you will want to insert a new record so you create a form that asks for all the information you require and then use the DA Insert SB to process the info and insert it into a database. Clear ?
davidp420108
yes I understand the concept of how it works. My question was how come there is no recordset on the insert record page?
I need information from a joined table,but the DA insert record seems to only let you reference one table at a time. In this case the table is "inventory_tbl" that the record is being inserted into, and I want the data from the parent table "dealer_tbl"
Do I need to create a session variable when the client logs in to capture some data from the dealer_tbl? I want to be able to reference the "dealer_folder" column in the "dealer_tbl". But the insert record seems to only look at inventory_tbl.
If creating the session variable is the option, please give me a pointer on how to do it and on which page. i.e. is it the login page or the page that a successful login directs them to?
This question is hard for me to formulate by typing so please be patient.
I think I see what you are asking, what I do is create a dropdown menu with the data required from the linked table as per the screenshot attached
davidp420108
I think we are way off track here. thanks for your replies, but i must be on the wrong path. let me ask a different question that should solve my problem.
Could you help me with creating a session variable?
What page do I create it on? the login page? or the page your are directed to after a successful login?
show me some sample code on creating a session variable please?
thanks.
PS I do have e-cart if that helps anything
simple code to set a session variable would like:
<?php $_SESSION['sessionName'] = "Session Value"; ?>
but I dont think this is going to help you very much.
let me ask a few questions and maybe we can get on the same track and i can give you more complete answers.
You are asking about setting a session when the user logs in, is the dealer_tbl you are referring to in the original question being used as your user table?
what are you using for Login, Security Assist? Or the Dreamweaver Authenticate user behavior?
davidp420108
I used security assist to create the login
dealer_tbl is the user table - (this is where the dealer_folder value is stored also)
I am trying to use some information, namely the dealer_folder, to use it in my path to where images are being stored. dealer_folder is auto generated when the account is made by using preg_replace[dealer_name]. Images should be stored to www.rankedontop.com/[dealer_folder]/images.
the problem i am having is accessing "dealer_folder" because the insert record behavior only "sees" the inventory_tbl, and the dealer_folder is in the dealer_tbl
thanks for your help.
even asking the question is hard. no wonder I can't figure it out :)
OK, so on the login page, Double Click the Security Assist Authenticate User server Behavior
Click next till you get to the Third Page, on this page, you can select columns from your users table that will be store into session values on login.
Select the dealer_folder column to have it stored in a session variable that you can use in the insert record behavior.
davidp420108
thanks Jason, i think this is what i was looking for. i wont be able to work on it till later, but i will reply to let you know.
David
you're welcome.
