Java errors
Thread begun 2/15/2011 6:20 am by randyw2394710 | Last modified 2/16/2011 10:45 am by Jason Byrnes | 5062 views | 10 replies |
randyw2394710
Java errors
I get java errors every time I use one of the pulldowns when creating the pages delete insert etc I have to click yes to allow continue script I think it says shared motools I have datta assist 2
do you have a link where i can see thew problem?
I will need to know the exact text of the error message to have any clue on what is causing the error.
randyw2394710
No I will have to Wednesday
randyw2394710
java errors
attached is the java scripts errors images
looks like you have a bad script reference on your page.
looks like there is a script tag:
<script src="files:\\\d:\web sites\multiinovations.com\js\mootools-core.js"></script>
this should not use a file system reference, but rather a document relative link:
<script src="js/mootools-core.js"></script>
randyw2394710
how do i fix this
change the bad script referance to document relative script referance:
randyw2394710
where do i change that location
you need to edit the code for the script tag.
randyw2394710
that is the whole point where is that script this is our script not mine im not getting much direction here
