DIGG URL not working
Thread begun 2/12/2011 5:28 am by jkul | Last modified 2/22/2011 1:18 pm by Jason Byrnes | 3415 views | 4 replies |
jkul
The DIGG will not work when using dynamic content. example URL?DID=<%=rsDB.blah%>
Dani Chankhour
Make sure that you are encoding that url parameter correctly. Here is an example of the code in php:
<a class="DiggThisButton DiggIcon" href="http://digg.com/submit?url=<?php echo urlencode('http://localhost/test/untitled2.php?test=3'); ?>"></a>
you can see that the url is being url encoded.
If you are still having an issue please post back with the code that you are using.
jkul
URLencode works for all. I USE classic ASP, so I created a variable, (some info shortend just to get the hint). varURL = Server.URLencode("http://www.myurl.com" + rsMyRecordSet.Field). Then used the <%=varURL%> as each post link.
jkul
I tanked this from my pages. It AINT working. The only ones i kept are Facebook, twitter and googlebuz. So what did i pay for?
can you send a copy of a page that is demonstrating the problem and link where we can see the issue in a browser.
