Published php pages don't function in browser or CS5
Thread begun 2/11/2011 7:15 pm by zonbeek284132 | Last modified 2/16/2011 6:36 am by Jason Byrnes | 2837 views | 5 replies |
zonbeek284132
After running the Wizard, my results in CS5 and FireFox are errors "The connection with the server was reset." and IE "cant display the page". Cant figure out or find information on this problem.
OS:Vista, Server: WAMP and CS5.
add the following code to line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
post back with any errors that are displayed and a copy of the page in a zip archive.
zonbeek284132
The only page that loads is "Search.php", because it's HTML. Safari, Firefox will not execute "Results.php",etc., before or after adding the error code. And no report.
I have other php pages I've coded that execute with WAMP server 2.1. Would there be a setting for the language version in the Wizard?
Results.php attached. note: CS5 reports the page with "No syntax errors".
I bet the issue is caused because the code is using the virtual function for include files rather than require_once:
try changing lines 5 - 9:
<?php virtual('/Connections/myCon.php'); ?>
//WA Database Search Include
virtual("/WADbSearch/HelperPHP.php");
<?php require_once('Connections/myCon.php'); ?>
require_once("WADbSearch/HelperPHP.php");
to prevent this from happening again in the future, change the setting in your site definition for "Create Links Relative to" from "Server" to "Document"
zonbeek284132
That was it! Thank you!
You're welcome.
