Can't Upload and download on the same page
Thread begun 2/11/2011 3:24 pm by Brad Lawryk | Last modified 2/14/2011 5:16 pm by Jason Byrnes | 5789 views | 10 replies |
Brad Lawryk
I just discovered that you cannot have an upload form and a list of the downloads on the same page. Why?
Downloads would always want to download the actual php page instead of the file. Soon as I commented out the Upload form the Downloads worked.
Brad
Most likely the upload and download behaviors are using the same trigger.
You will need to use a unique trigger for the upload and the download behavior in order for them to work on the same page.
Brad Lawryk
Thats what I figured but no dice. I tried setting each one to trigger on the specific button press even and it still didn't work.
send a copy of your page please.
Brad Lawryk
I can't send a copy because its an internal government site. I will try recreating it with different data on my own server.
Brad Lawryk
Actually, here is one I tried doing up as a prototype and upload test for a customer who wanted to see upload speeds.
uploadtest.php
Brad
can you send a copy of the actual php page please.
Brad Lawryk
Here you go ...
the issue in this file is that you have bound the download to use the doc_file file field as the download file source, you can only download a file that exists on the server.
Another issue is that The doc_file file field is not part of the same form as the download button that triggers the download.
Brad Lawryk
But the file does exist on the server ... and the download is set to a hidden field in the download form exactly like your instructions say.
If I comment out the upload form the download works perfectly.
