Hosting change
Thread begun 2/11/2011 2:25 pm by DaveTurton | Last modified 11/16/2011 4:50 am by jhnsmth166401290 | 5167 views | 6 replies |
DaveTurton
Hosting change
I moved my original hosting from Hostway to Godaddy. I hadn't really finished building my store and it wouldn't really matter if I had to reinstall it again. My question is what am I going to run into with this? Will there be some activation errors since the IP will be different?
DaveTurton
If I reinstall it, can I still use my serial number that came with the purchase?
neilo
Hi Dave,
You should be able to install it without any problem, using the same serial number, as long as the original installation is not left in use. WebAssist allows an extra installation for testing purposes, which is in essence what you have been going through.
DaveTurton
Thanks Neilo, I'll give it a whirl.
DaveTurton
That worked, thanks Neilo
neilo
Cheers Dave.
jhnsmth166401290
Re:
Before you start searching for a suitable web hosting service, you need to know the requirements of your website. It may happen that if you do not know the things which are required by your website, you might end paying for something which you really do not require. Managed IT
