Power Gallery not working
Thread begun 2/11/2011 10:27 am by mrobben375515 | Last modified 2/11/2011 1:12 pm by Jason Byrnes | 3945 views | 5 replies |
mrobben375515
My power gallery is not working. One of the images is linked as "http://cutestpetcontest.com:443/galleries123/images/1/100382254_62c.jpg". Why is there the extra ":443" after the domain name? The settings in the database are below
pg root = "/galleries123/"
pg root url = "http://cutestpetcontest.com/galleries123/"
this is happening because you are redirecting http to https
in the mediarss.php file change:
$WAGLOBAL_Root_URL = ((isset($_SERVER['SERVER_PROTOCOL']) && strpos($_SERVER['SERVER_PROTOCOL'], 'HTTPS') !== false) ? 'https://' : 'http://') . $_SERVER['SERVER_NAME'] .( (isset($_SERVER['SERVER_PORT'])&& $_SERVER['SERVER_PORT'] != 80)?":".$_SERVER['SERVER_PORT']:"") . $assumedRoot;
$WAGLOBAL_Root_URL = 'https://' . $_SERVER['SERVER_NAME'] .  $assumedRoot;
you will also need to make this change in the galleries/global.php file.
mrobben375515
Thank you, now that gallery works. I tried to insert another gallery into a product description page. I pasted it into the source but it's not showing up. It should be under "PRODUCT IMAGES". When I paste it into a page using the php string it works fine, but not in the product description using the <input> form.
Here's the url to the product...Products_Detail.php?ProductID=1
Here's the url to it in a page ... Ordering.php
Have you implemeted the Database Integration update from the Power Gallery download center page?
mrobben375515
Ahha, thank you
you're welcome.
