Prices varies by total order weight
Thread begun 2/10/2011 11:56 pm by info4753 | Last modified 2/15/2011 7:02 am by Jason Byrnes | 5808 views | 9 replies |
info4753
Our customer has products with 3 different prices, based on the total weight of the order. If the total weight of the order is below 1000kg, I have to use the normal price, between 1000 and 3000 kg use price with the first discount, over 3000 price with use the second discount. The discounts are based on the products themselves not on any categories. Each product has its own price and discount prices.
Example:
Product1 has
Price1 (under 1000kg total order): 100 CHF
Price2 (more than 1000kg total order): 95 CHF - Discount 5 CHF
Price3 more (more than 3000kg total order): 90 CHF - Discount 10 CHF
Product2 has
Price1 (under 1000kg total order): 105 CHF
Price2 (more than 1000kg total order): 95 CHF - Discount 10 CHF
Price3 more (more than 3000kg total order): 90 CHF - Discount 15 CHF
etc...
I guess the best way to start would be to add the two discounts as two fields in the product table with values of (for Product1) discountPrice2: CHF 5 and discountPrice3: CHF 10.
I tried to find a suitable trigger and corresponding calculation but can't find a way to go.
Or can I chance the prices in the cart on thy fly when the total weight excees 1000kg?
How do I solve this problem?
Thanks for any help in advance.
add 2 new columns to the eCart object:
dicount1
discount2
on the calculations tab, add to new calculations:
totalDiscount1:
[discount1] * [Quantity]
totalDiscount2:
[discount2] * [Quantity]
Next On the discount tab, create 2 discounts:
Name: 1000kg - 3000kg
Triggers:
Subtotal For Any Column:
If the subtotal for column 'Total Weight' is '>' a value of '1000'
AND
If the subtotal for column 'Total Weight' is '<=' a value of '3000'
Calculation:
Column Subtotal:
Subtotal of Column 'totalDiscount1' 'plus '0'
Triggers:
If the subtotal for column 'Total Weight' is '>' a value of '3000'
Calculation:
Column Subtotal:
Subtotal of Column 'totalDiscount2' 'plus '0'
in the add to cart button for each product, set the Price Column to the regular price. Set the discount1 column to the discount for the second weight break (i.e. 5 for product 1, 10 for product 2), and set discount2 to the discount amount for the third weight break (i.e. 10 for product 1, 15 for products 2)
info4753
Thx Jason, I will give a try ... :-)
you're welcome.
info4753
It's not working. The discount are not beeing calculated. Maybe this is a "number" / "currency" problem?
Also, totalWeight seems to be summarized on each cartItem row, but it should be summarized by the total of all the cart items rows.
I guess I need a CartTotalWeight. How do I realize this?
Send me a copy of the eCart include file and a link where i can see the problem.
info4753
Add products to cart:
artikel.php?PRODID=44
artikel.php?PRODID=43
Shopping cart:
warenkorb.php
In the discount rules, you have selected the wrong column for the discount calcualtion.
You should be using the totalColumn1 and totlacolumn2 column totals for the discount, instead, the rules are configured to use the totalDiscount1000 and totalDiscount3000 columns
info4753
Thanks again, now it works. I've also had to change the weight range to 1000 - 2999.
you;re welcome, glad to hear it is working.
