Image Display Issue after changing path
Thread begun 2/10/2011 10:25 am by Martin | Last modified 2/22/2011 10:18 am by Martin | 3021 views | 3 replies |
Martin
Greetings,
I have just moved my power cms from my testing server which was on a subdomain test.mydomain.com and I have moved it over to the live domain www.mydomain.com.
Ok, I have gotten all the content variables working with the path:
/var/www/vhosts/mydomain.com/httpdocs/cms_admin/WA_CMS/addtosite.php
However, I am getting broken images in the image path even though the path of the broken link on the page is exactly correct and what I want it to be.
Probably it wants to go and get the image from posterior-r1800-185x185.gif.
How can I force this to go up a level and get my images from my main images folder on the root level?
I already have it set to the following:
/var/www/vhosts/mydomain.com/httpdocs/cms_admin////../media/images
in the image upload folder settings...
I have checked int he DB and the PCMS Remote Root is set as /cms_admin/
Your help would be appreciated, as I am implementing this on an existing domain and it would be helpful to access all the images that are contained on the root level and new images may as well go into the same main folder.
Thanks,
Martin
Martin
I just did a bit more checking and one image src comes up as
src="/cms_admin////../media/images/posterior-r1800-185x185(1).gif"
And the other comes up as
src="/cms_admin//../media/images/posterior-r2005-185x185.gif">
I hope this gives you more information!
Thanks,
Martin
Martin
Thanks to a call from Ray at Web Assist and his help to get this working.
Ended up being something in the way FCK editor handled paths conflicting with the CMS DB.
All working now! Thanks, Ray!
