SA registration linking to other forms
Thread begun 2/09/2011 10:15 pm by scott417485 | Last modified 2/11/2011 6:31 am by Jason Byrnes | 2061 views | 3 replies |
scott417485
Hi guys
I have security Assist set up and working for registration to my site. I have a table in the mySQL database for members with their registrations details, and need to reuse this information on licence, entry and logbook forms which also have tables under the same database as the registration table is in.
There are tables in the database also for PowerCMS and PowerGalleries which are working OK, just cant get the registration details to link up to the other forms. Any ideas.
cheers and thanks in advance
scott
your other tables should have a foreign key column that will relate to the user table.
when the user logs in using security assist, the users ID will be stored in a session variable
See the profile page, if you examine the recordset, you will see that is filtered on the users ID session variable.
in your forms that insert data that will be related to the user, set the foreign key column of the other tables to use this user id session variable.
scott417485
Hi Jason
Many tanks for your quick reply, has solved a couple of the problems will test the rest tonight.
Cheers
Scott
you're welcome.
