Icons not working properly
Thread begun 2/09/2011 9:59 pm by craig422148 | Last modified 2/22/2011 1:19 pm by Jason Byrnes | 5824 views | 9 replies |
craig422148
The icons are not showing up properly on my website.
View Here:
winnipegcafes.php
What do I need to do to fix this problem?
Thanks.
Neil Beadle
It looks like the "wasocial.css" style sheet is not being applied to your page.
The path to the style sheet does not look correct:
"../../../../Documents/Unnamed Site 4/webassist/social/wasocial.css"
This probably means that your Dreamweaver site was not defined properly when you inserted the Share buttons to your page.
Also, make sure you upload the webassist folder to your site when you upload the page you added the buttons to.
Hope that helps!
-Neil
craig422148
I definitely have the site defined now and uploaded webassist folders and STILL same problem.
winnipegcafes.php
Looks like others are having same problem.
What now?
Neil Beadle
Hi Craig,
Sorry this is not working for you.
When i look at the <head> of your page, i am still seeing this:
<link rel="stylesheet" type="text/css" href="Documents/Unnamed Site 4/webassist/social/wasocial.css"
<script type="text/javascript" src="../../../../Documents/Unnamed Site 4/webassist/social/wasocial.js"
try changing these two lines to this....
<link rel="stylesheet" type="text/css" href="../../../webassist/social/wasocial.css"/>
<script type="text/javascript" src="../../../webassist/social/wasocial.js"></script>
-Neil
craig422148
I just got off the phone with my serve hosting company. The mysql is still 3.0. This would be the problem ... correct? I am going to need to change companies because the power cms would not work either.
Thanks for the help. Maybe this is why those others are having problems too.
Neil Beadle
Craig,
Social Media Toolkit does not require MySQL. The issue i posted above seems to solve your Share buttons issue.
However, for PowerCMS you would need to update your version of MySQL.
-Neil
garryskaggs351850
Out of loop
I seem to be out of the loop because I have had the flu for a week. When I started this thread I thought it was going to be simple but this simple social media toolbox seems to be more of a problem than what it is worth. It works fine on a simple page but using it in a template or anywhere else has become a problem. I can't but it up for anyone to see because it looks like crap and the site is live.
neilo
Hi Garry,
Please could you post a link to a page that is showing the problem?
craig422148
Subdomains.
The social icons work like this:
website.com/subdomain.com
but not like this
subdomain.website.com
I tried changing the script in my web page but to no avail.
Any suggestions?
send a link where i can see the problem to investigate the cause.
