Image Resizer - Fatal Error Max Execution Time
Thread begun 2/09/2011 5:24 pm by dlovas275157 | Last modified 2/11/2011 7:00 am by Ray Borduin | 7178 views | 8 replies |
dlovas275157
I have applied the Image Resizer server behavior to two images on my page, and I get the following error on page load:
Fatal error: Maximum execution time of 30 seconds exceeded in D:\Inetpub\servername\siteprefix\webassist\caching\CachedResize_Image.php on line 298
Note:
File permissions have been opened up on the folder storing the thumbs so that is not the issue.
GD Library is enabled (GD Support - enabled) so this is not the issue either.
Attached is my code.
Thanks for any help.
Verison: 1.0.0
try adding the following code at line 1:
<?php ini_set('max_execution_time'0); ?>
dlovas275157
I added that line of code to line 1, and now the page won't load....hangs for a long time then posts the following error:
FastCGI Error
The FastCGI Handler was unable to process the request.
Error Details:
The FastCGI process exceeded configured request timeout
Error Number: 258 (0x80070102).
Error Description: The wait operation timed out.
HTTP Error 500 - Server Error.
Internet Information Services (IIS)
What are the image dimensions and file size of the image you are using?
GD library sometimes wont process large images and you need to save them as a smaller image before using them on the web.
dlovas275157
The image is originally 1000 px W x 667 px H
and going to
160 px W x 120 px H
Sounds reasonable...is this too much?
How large is the image in KB? Can you upload a copy of the image so we can test with it? Does it work with smaller images?
dlovas275157
Ray,
The file sizes vary from 130 KB to 20 KB.
Attached is one of the files to test with.
dlovas275157
Tried it with a single 20 KB image 325 x 244 px to resize down to 160x120. Attached is code. Still doesn't work...says it times out at line 298 of CachedResized_Image.php.
Line 298 is:
$phpself = dirname($phpself);
Does this help troubleshoot?
I opened a support incident so that we can debug this with you directly.
