fopen fwrite fclose trouble
Thread begun 2/09/2011 4:18 pm by alain28963 | Last modified 2/15/2011 8:24 am by Jason Byrnes | 7008 views | 8 replies |
alain28963
My powercms2 is intalled and work since 3 good weeks. I have not touch it since 1 week.
I come back totay powercms2 and I have this error message.
Warning: fopen(../Connections/installed_cms.txt) [function.fopen]: failed to open stream: Permission denied in /var/www/vhosts/tubefamily.net/httpdocs/powercms2/images/installed.png on line 19
Warning: fwrite(): supplied argument is not a valid stream resource in /var/www/vhosts/tubefamily.net/httpdocs/powercms2/images/installed.png on line 20
Warning: fclose(): supplied argument is not a valid stream resource in /var/www/vhosts/tubefamily.net/httpdocs/powercms2/images/installed.png on line 21
What is this ????
How to fix it ????
here is a new copy of the installed.png file to correct the problem, copy it to the following folder in your site:
admin_gallery/images/installed.png
also, edit the admin_gallery/global.php file, change lines 34 - 37:
require_once("images/installed.png");
//PowerGallery version
$wa_settings['pg_version'] = '1.2.0';
mysql_free_result($result);
alain28963
The folder not on powercms2
The forlder you talking about are not on powercms2 (WEB site and Download ZIP installation)
I add in attachement a JPEG with the folder tree of powercms2 on the web site
Can you give me more help ?
neilo
I think you might find it in at yoursite.net/powercms2/images/installed.png.
Try replacing that one, to see if that fixes the issue.
alain28963
Still have one line error
I transfert the png file to to images folder and still have an error message
(I keep a bkup before)
Look at for the error message :
powercms2
Also, I do not modify the admin_gallery/global.php I don't find it
Please help !
neilo
Hi Alain,
Apologies, I think there was some confusion over which application we were referring to.
Please could you try unzipping and uploading the attached installed.png file to replace the existing one.
Don't bother with the admin_gallery/global.php.
alain28963
Still not work
I try it and the message still be there
users_login.php
neilo
Hi Alain,
Sorry this is an ongoing problem for you. Please could you check the permissions for your powercms2/Connections folder, and check that they are set to 755?
