Big problem
Thread begun 2/09/2011 7:58 am by mick106153 | Last modified 2/10/2011 10:28 am by Jason Byrnes | 3399 views | 5 replies |
mick106153
Big problem
I'm having a big problem that needs (please) immediate attention.
Go here
products_results.php
if you select "next" at the bottom of the list - no problem.
If however you first choose any selection in the column on the right and than choose "next" at the bottom of the resultant list your taken to
whatever.......products_results_xml.php etc.
rather than
whatever.......products_results.php etc.
Needless to say (I will anyway) Ouch! Help please
Mick
See the Known Issues section of the Power Store Download center page for a fix to this issue.
mick106153
Thanks Jason
It says
"The pagination on the products results page may not work correctly if PowerStore is installed in the root of the remote site.
Note: This issue will not occur if you install PowerStore in a subdirectory of your site; you should only apply this fix if PowerStore is installed at the site root."
My site is at htdocs/bole
and the store is at
htdocs/bole/store
Which means its not at the root - I think.
Am I right or wrong?
Mick
on the webassist/plugins/catalog/results.php and results_grip.php pages, change:
if (!isset($currentPage)) {
$currentPage = $_SERVER['PHP_SELF'];
else {
$currentPage = dirname($_SERVER['PHP_SELF']) . '/' . $currentPage;
$currentPage = str_replace("_xml","",$_SERVER['PHP_SELF']);
else {
$currentPage = dirname(str_replace("_xml","",$_SERVER['PHP_SELF'])) . '/' . $currentPage;
mick106153
Thank You!
Worked perfectly!
Yours
Mick
glad to hear it is working.
