Problems with email template
Thread begun 2/09/2011 3:06 am by info321189 | Last modified 2/17/2011 11:21 am by Jason Byrnes | 3011 views | 4 replies |
info321189
I use:
Dreamweaver CS4
Universal Email 4.0.1 (with xml fix)
When I send email with template I receive errors from database.
I attach the pages, the userdata_email.php is the page that have the extension UE, the waue_userdata_email_1.php is the page inside folder 'webassist/email', the user_data_template.php is the template inside dir 'webassist/email/templates'.
When the email is sended I receive this:
Hello
Notice: Undefined variable: row_rs_userdata in C:\wamp\www\mysite\webassist\email\templates\user_data_template.php on line 3
Your data Here
Name:
Notice: Undefined variable: row_rs_userdata in C:\wamp\www\mysite\webassist\email\templates\user_data_template.php on line 6
Email:
Notice: Undefined variable: row_rs_userdata in C:\wamp\www\mysite\webassist\email\templates\user_data_template.php on line 7
P.S. Inside the file mailformatting_php.php located in folder 'webassist/email' at line 55 I see 'require_once("../database_management/wa_appbuilder_php.php");' this directory and file doesn't exist.
Add this to the top of the email body template page:
global $RecipArray;
global $CurIndex;
and in the email body, use this syntax for referencing the recordset columns:
<?php echo($RecipArray[$CurIndex][0]["[yourColumnName]"]); ?>
info321189
Hello Jason, with this way I got same errors ( I think to wrong the syntax )
I found a simple way like yours pre-built solutions, in the file 'waue_userdata_email_1.php'
I change around line 38...
//Start Mail Body
$MailBody = $MailBody . "";
$MailBody = $MailBody . (GetFromPage("templates/user_data_template.php"));
//End Mail Body
with this
//Start Mail Body
ob_start();
require_once(dirname(__FILE__) . ("/templates/user_data_template.php"));
$contents = ob_get_clean();
$MailBody = $MailBody . ($contents);
//End Mail Body
info321189
another problem...
Hello, another problem.. if I send the email to a recordset loop only the first email is received correctly, other emails sended have empty body...
see this thread for details on how to fix this issue:
showthread.php?t=17869
