CSS Form Builder Build 23 with HTML Editor Ver 3
Thread begun 2/07/2011 1:08 pm by jim332262 | Last modified 2/08/2011 2:06 pm by Jason Byrnes | 3115 views | 5 replies |
jim332262
Problem: Receiving the DW error message “Error trying to upgrade present: Syntax Error: syntax error” when opening the file “admin/contents_update.php”.
Installed Extensions: DW Extensions installed: Site Sculptor 1.0, CSS Form Builder 2.0 Build 23, HTML Editor 3.0.
This is a repeatable problem. I have taken the following steps that have not resolved the issue:
> Uninstalled all extensions
> Deleted the DW cache file
> Reinstalled all three extensions in the order listed above.
Am curious if I am doing something wrong or there is a problem.
Thank you for any help/guidance.
are you trying to edit the HTML instance on the PowerCMS Contents update page?
see the following thread for details on updating PowerCMS to use HTML Editor 3:
showthread.php?t=18415
jim332262
Yes. Specifically attempting to change/edit the Site Styles using the process outlined by Neilo in other forum posts.
you cannot edit an HTML Editor 2 instance, you need to delete the HTML Editor 2 instance, and replace it with an html editor 3 instance as outlined in the post I linked to in the previous reply.
jim332262
Thanks Jason! I will follow the instructions provided in your post. I appreciate your time and response!
you're welcome.
