Multiple Instances of DatePicker
Thread begun 2/07/2011 11:39 am by paul266518 | Last modified 2/09/2011 2:02 am by paul266518 | 3403 views | 2 replies |
paul266518
Apart from the initial problems of template - blah, blah... but my real headache is the way the js code is setup...
1. the extension realised that there were multiple datepicker controls - but after some failed attempts landed up with datepicker_1, datepicker_5, 6, 7, 8, and 9 !
2. the code was replicated for each - including jquery and the css - pointless
3. Surely it would have been better to have the code look for datepicker_xxx?
4. Some datepicker controls out "there" have a display format and a storage format - that would be really neat...
I have a logged a bug for the duplicated code and a feature request for the storage format.
I'm not sure I understand why datepickker_xxxwould be better than the datepicker_x format that is used? if you add 10 of the date pickers, it will still increment to datepicker_10 and so on.
paul266518
You are absolutely right - I've just been in IT far too long (30 years) - and would often put a mask of "xxx" just to show it goes on for ever....!!!
I'm ok with the actual datepicker control itself - the default set of skins are pretty good and useable - and don't clutter the code with junk which is an added bonus!
Cheers
