Problem Altering email and Captcha after form builder 2
Thread begun 2/07/2011 10:43 am by bhblake | Last modified 2/07/2011 1:35 pm by Jason Byrnes | 2453 views | 3 replies |
bhblake
I have gone through the entire form process in form builder 2 adding both an email address as well as a captcha security from within that extension.
So when I am in dreamweaver and I click to update the captcha form toolkit opens. So I make my alterations there. Upon test the captcha stops working correctly and just keeps reloading without validation. I went in an added validation to it and still the same error.
Now i also wanted to add an "go to" page when I submit my form; so I launched universal email and added the same settings again as well as my "go to page" link.
The entire form is no longer functioning correctly, what is the correct way to go about this updating process without causing issues?
Thanks.
For the captcha, you should edit the form layout and use CSS form builder to edit the look of the captcha element.
to edit the Universal Email settings, open the Server Behaviors panel and double click the Universal email server behavior.
bhblake
Captcha is different
Jason -
Is there a way to add a captcha refresh button from form builder? It's an available option in the toolkit - but not Form builder. Please advise.
Thanks again.
No, css form builder does not include the refresh button.
you would need to replace the captcha from form builder with the one from Form Toolkit.
Delete the captcha element from the form, then add a new one from Form builder.
In the server behaviors panel, double click the server validation server behavior, remove the existing Lie Entry Validation for the captcha form element, and add a new like entry validation for the form toolkit captcha element, instructions for configuration the like entry validation are in the form toolkit getting started guide.
