Source code showing instead of HTML
Thread begun 2/07/2011 2:49 am by gstoyle396649 | Last modified 2/07/2011 11:16 am by Jason Byrnes | 2250 views | 3 replies |
gstoyle396649
I've just upgraded to v3.
The HTML code isn't rendering in the main display - I can only see the source code.
There doesn't seem to be any option to enable this.
This will happen if there is any formatting on the Initial Value of the editor instance.
Do you have the initial value for the HTML Editor instance coming from a recordset? or other dynamic source?
If so, edit the HTML Editor Instance, and click the lightning bolt next to Initial Value, reselect the Dynamic source and make sure that no formatting is applied.
gstoyle396649
Thankyou, that did the trick.
Glad to hear it is working.
