PowerStore4 page customization
Thread begun 2/04/2011 10:27 am by Earth Tribe Studio | Last modified 2/07/2011 6:41 am by Jason Byrnes | 1635 views | 1 replies |
Earth Tribe Studio
In previous versions of PowerStore I was able to customize the pages & menus pretty easily. In PowerStore4 I am not sure where to start. I am currently using the "Crazy" theme and would like to customize it a bit. First of all I would like to remove the "banner" image on the right side of the "middle pod" and utilize the entire "middle pod" for a Flash element.
Also as far as the navigation goes, I would like to move the About Us drop down tho the main navigation & change the name to directions.
Thank You.
You can remove that image from the design Section. In the design Editor, you can select images, then set the banner image source to none.
Then in the content management section, you can add your flash to the Middle Pod -> Content content area.
