Nested Array
Thread begun 2/04/2011 7:47 am by swolock397582 | Last modified 2/04/2011 12:51 pm by Jason Byrnes | 1698 views | 1 replies |
swolock397582
Nested Array
I have a table with 100 widgets (widget 1-100). The 100 widgets are grouped into 5 different categories (category A-E). In 5 variables, 1 for each category, I would like store the IDs for each widget in the category. So $categoryA = id1, id13, id45, etc., $categoryB = id6, id9, id20, etc., and so on. Is this doable?
I appreciate anyone's help with this. Thanks
create a recordset for each category to return the records for that category: for example:
rsCatA:
SELECT widgetID FROM widgets WHERE category = 'categoryA'
then use a recordset repeat to add each id to an array;
$categoryA
= array();
do {
$categoryA[] = $row_rsCatA['widgetID'];
} while (
$row_rsCatA = mysql_fetch_assoc($rsCatA));
you can display the ID's as a comma separated list using this code:
<?php echo(implode(", ",$categoryA)); ?>
