correct syntax for 'To' settings
Thread begun 2/03/2011 8:14 am by CraigR | Last modified 2/07/2011 1:24 pm by Jason Byrnes | 4511 views | 11 replies |
CraigRBeta Tester
After starting afresh, (again), i can create an email message which sends successfully to one recipient.
when i attempt to select recipients from a recordset to use in the 'recordset loop' , whenever i save the changes and then re-open the server behavior, the 'from file' option is selected.
on my mail page, the $recipArray line reads as follows..
$RecipArray[$CurIndex] = EmailArrayFromFile("rsmembers.MemberEmail");
even if i selected recordset loop.
is this correct ?
No, this is not correct, I started a ticket for this issue for you on your other thread, an engineer will need to contact you to look into the issue and find the cause.
Please update the ticket that was started with contact information so we can debug the issue with you.
CraigRBeta Tester
Hi Jason.
I updated the ticket with my contact info yesterday.
I closed this ticket as I couldn't reproduce the original problem. but the contact info still stands
in the meantime, can you tell me the correct syntax so I can hand code for now ?
I can't seem to find the relevant function in mailformatting_php.php
thanks
in your file, you have:
$CurIndex = sizeof($RecipArray);
  $TotalEmails += sizeof($RecipArray[$CurIndex]);
that should be changed to:
  $RecipArray[$CurIndex] = array();
  $RecipArray[$CurIndex][] = $row_rsmembers;
  $RecipArray[$CurIndex][] = $rsmembers;
  $RecipArray[$CurIndex][] = "MemberEmail";
  $TotalEmails += mysql_num_rows($rsmembers);
CraigRBeta Tester
thanks Jason.
I typed that in to replace the original code, and now the mail is sent correctly.
to try and finish off. I want to use my recordset to include the first name of each member for their respective email.
I read in another thread about adding $RecipArray etc as globals and using this instead of the recordset , but again, the changes I make don't seem to stick if done via the wizard.
Is this the correct approach to take ?
the changes should not be made through the wizard, make the changes after running the wizard.
CraigRBeta Tester
sorry. i meant the server behavior interface, as opposed to editing the code directly.
The changes don't save to the page
yes, i understand, you should not make the changes in the server behaviors interface, you need to make the code changes directly in the code.
if you edit the server behavior, they will be erased and you will need to make the changes again.
CraigRBeta Tester
great, making progress
thanks Jason.
After creating the basic email, I am now hand coding so I don't overwrite anything inadvertently.
i have also included html editor 3 onto my page.
I have 2 questions relating to html editor..
1. the message created in the htmleditor has very wide line spacing after each cr/lf, how can i reduce this ?
2. apostrophies are not escaped, so "can't" is shown as "can\'t" in the message
Using 2 recordsets on the page.
in order to personalise the email, i am using the syntax $MailBody = $MailBody . ($RecipArray[$RecipIndex][0]['MemberFirstName']);
my mail page has 2 recordsets.
the user will choose an event a list, whose id I use as a url parameter in a link, but i also want to include the event description in the link
can you tell me how to achieve this ?
By default HTML Editor uses P tags for the enter key.
in the HTML editor instance, go to the Formatting tab and select the option to use BR for enter instead.
for the escaping issue, try adding this at line one of your page:
ini_set('magic_quotes_gpc','on');
for the delected event title to show in the email, you will need to set the event recordset to filer the eventID column on the eventList select list.
