Template won't connect to MySQL
Thread begun 2/03/2011 12:42 am by neo314 | Last modified 2/04/2011 1:10 pm by neo314 | 2809 views | 4 replies |
neo314
I am using UE 4 and I am trying to send an email as the final step in a transaction. I am using a session variable to pass the key to the template file.
What I am getting is:
Warning:  mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /var/www/html/domain.com/webassist/email/templates/invoice.php on line 44
I have checked the connection file path and it is correct. I even tried changing it to a static path:
<?php require_once($_SERVER["DOCUMENT_ROOT"].'/Connections/conn.php'); ?>
if (!isset($_SESSION)) {
session_start();
Is there something about templates I am missing. If I try to just make a DW file, using the DW button in the GUI, I get too much of the page's template, so an external file would be desirable.
neo314
I think I figured out the template issue, but I cannot edit the template except for the first time I use it. I tried a default template followed up with using framework to include the file (static), but I get the same results.
"mysql_select_db(): supplied argument is not a valid MySQL-Link resource..."
neo314
Well I hope to get a reply to resolve the issue. Creating the email on the page from which it is to be sent includes way too much junk from the page's template and invariably breaks. I have not been able to get a database connection or a framework include with a database connection from either sending the email through a clean file (no page template), or an email template.
I resolved the problem through straight PHP getting the contents of the file and pulling out just the BODY content out of it. I put this code in an email template and it works.
$file = file_get_contents("http://".$_SERVER['SERVER_NAME']."/path/to/file/invoice.php?key=".$_SESSION['key']);
$body = preg_replace("/.*<body[^>]*>|<\/body>.*/si", "", $file);
echo $body;
the connection and recordset should be created on the main page that you apply universal email to, not in the template file.
In the email template file, you can use the recordset data, but the code to create the actual connection and the recordset itself should be on the main page.
neo314
Ok, I see that from the response I get from the server, but that seems to be a problem on two fronts.
1. If I use the framework module in other pages, it has to have the db connection in the file, so I cannot use that module in an email. It would be beneficial to use a framework module in an email or on a web page. My invoice is a module on the page. Other dynamic modules include event ended and soldout for example. The invoice module has a db connection and is also what I want to email.
2. Is there any way to bind the data source from the main page to the template file much the way WA provides the ability to bind form data from another page. That would be helpful.
