File Download
Thread begun 2/02/2011 10:48 pm by danielsebas | Last modified 2/05/2011 12:00 pm by Jason Byrnes | 1926 views | 3 replies |
danielsebas
File Download
Hi, I am trying to apply two download behaviors in one page but only the first works (WA_DownloadResult1), and if I invert the order of the behaviors the one that will work will be (WA_DownloadResult2) the code is generated like this:
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult1");
if(($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)){
WA_DFP_DownloadFile("WA_DownloadResult1", "../files/ringtones/", "".((isset($_POST["name"]))?$_POST["name"]:"") ."", "[FileName]", 1, $database_DatatablesConn, $DatatablesConn, "products", "ProductID", "".((isset($_POST["product"]))?$_POST["product"]:"") ."", "ProductCount");
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult2");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_DownloadFile("WA_DownloadResult2", "../files/songs/", "".((isset($_POST["name"]))?$_POST["name"]:"") ."", "[FileName]", 1, $database_DatatablesConn, $DatatablesConn, "products", "ProductID", "".((isset($_POST["product"]))?$_POST["product"]:"") ."", "ProductCount");
Thank you in advance.
Note: I am using two tables with two different recordsets, one for the ringtones and other for the songs the forms have different names and the hidden fields and download button have the same names becuause I am also using a DataAssist insert behavior to count in another table (downloads table) the downloads and the ID of the user that downloaded the file
the issue is that you are using the same form element for each download. This will trigger the first download to happen and prevent the second, you cannot do two download behaviors at the same time.
The work around is to create 2 separate submit buttons, One to download the ring tone, the second to download the song. Then in the Download file server behaivor, select the Buitton Pressed trigger for the coresponding button.
This will cause the ringtone download to happen when the ringtone button is pressed and the song download to happen when the song button is pressed.
danielsebas
Thank you Jason, now it worked
glad to hear it is working.
