Bug: unescaped table columns on select
Thread begun 2/02/2011 2:23 pm by 0001421801 | Last modified 2/02/2011 2:51 pm by 0001421801 | 1727 views | 2 replies |
0001421801
It actually crashes DW from which I have sent in the automatic Apple/Adobe crash reports.
Generated via the Data Assist Wizard...
Unfortunately I'm having to deal with an already running database which I can't change:
The originator who wrote out the schema used "order" for one of the table columns.
That blows an error because the code generated didn't think to escape it.
$query_WADAClassroom = sprintf("SELECT id, name, `order` FROM Classroom WHERE id = %s", GetSQLValueString($Paramid_WADAClassroom, "int"));
Just in case anyone runs into that.. it didn't hit me for a few minutes, save your self some hair. :)
As a test I changed the table column name to Corder and ran the wizard again.. no crash.
it is recommended to avoid using MySQL Reserved words when creating your data base schema for this reason.
I know that.. the person who did the schema didn't. :) Now I can't change it..he's built an iPad app around it.. I'll have to let him know though. DataAssist should check for that though.. I thought DW did when it did it's Server Behaviors.
