Data Assist Insert Page
Thread begun 2/02/2011 10:04 am by mrobben375515 | Last modified 2/04/2011 7:33 am by Jason Byrnes | 2947 views | 3 replies |
mrobben375515
I selected the school_ID (which is set to the key column), to show up as a text field on the insert page. However, it didn't show up. I tried it a couple more times with no success. So I put the text field in manually and tried to configure the insert code but now I'm getting a php error. I need to be able to insert a school ID because if I don't then when I click the update button it can't query correctly. But I don't want to have to go into the database and set up a school ID either. I've attached the page, and the error message is below.
Fatal error: Call to undefined function WA_AB_generateInsertParams() in /home/content/50/7015650/html/Admin/ssinsert.php on line 28
the issue is that the school_ID column is set to be the Index Column.
you should not be entering anything in the index column.
the index column should be the primary key column in your database.
You should set the primary key column to be an auto number column so that the database will assign it a unique ID.
Set the school_Id to be an auto increment column in the database and let the database handle giving the school an id.
the error is occurring because your page is missing the following line:
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
mrobben375515
Gotcha. Ok, i changed the id column to auto populate. Now when I insert the "Proof File Name" and "product ID" fields I have set up don't show up in the database. I have 5 other fields that show up fine, but those 2 don't.
Also, when I try to delete a file I get the following error.
Fatal error: Call to undefined function WA_AB_generateWhereClause() in /home/content/50/7015650/html/Admin/ssdelete.php on line 70
I've upload both files for you to look at. Thanks
the insert page has 2 problems:
1) The proof file name and product ID columns in the database have spaces in the name, this is not valid for naming database columns.
2) the proof file name and product ID Form elements on the page have spaces in the name. this is not valid for naming form elements.
On the delete page, move this code at line 81 - 84:
<?php require_once( "../WA_Globals/WA_Globals.php" ); ?>
<?php require_once('../Connections/PowerStoreConnection.php'); ?>
<?php require_once('../WA_CMS/WA_CMS.php'); ?>
to line 1
