CMS with H1, H2 etc tags
Thread begun 2/02/2011 7:46 am by alistair316863 | Last modified 2/08/2011 1:34 am by alistair316863 | 5468 views | 13 replies |
alistair316863
Hi for some reason with Power CMS all of a sudden when I apply a format of Heading 1 etc the line spacing goes massive unless I go into the source and change it from:
<h1><span class="whatever">Title</span></h1> to
<h1 p class="whatever">Title</p></h1>
Have I changed something by mistake as this is ok for me but my clients won't have a clue (nor should they have to have)
See Attached screen Grabs - Thanks Alistair
this is not vaid markup:
valid markup would be:L
<h1><p class="whatever">Title</p></h1>
it sounds to me like the issue is in the style definition for the whatever class being applied to the span.
what if it's just a plan h1 tag:
<h1>Title</h1>
with no styling applied, does that look better, if so look int the setting for the whatever class.
alistair316863
Hi Jason if I just use <h123456></h123456> it is ok, but if I use my stylesheet which I have brought into the HTML Editor it dosent so I checked my css style sheet and kept stripping out until I was left with:
.text12 {
font-family: "Times New Roman", Times, serif;
font-size:12px;
But still no Joy (see attached) also if I go to contents insert and update page to add my style sheet that way I get this error:
Error trying to upgrade preset:
SyntaxError: syntax error
If i click ok I can get to the HTML Editor
Just to let you know I have just upgraded to version 3 dont know if that helps
please send a link where i can see the problem to investigate.
alistair316863
At the moment I am testing locally so I cannot send you a link but I have zipped up what I have done so far and put all files on my ftp server see attached txt file cheers Jason
nb also attached DataBase
Ok, I downloaded your site files, but you will need to provide some direction on where I should be looking for the problem.
What page are you outputting the CMS content where you are seeing the issue?
alistair316863
It dosent really matter select any text and change it to a h1 or h2 and you will see
I cant reproduce the issue by just applying the h1 tag to data you already have, I was asking for a way to see what you have already done so I could see the issue.
On what page are you seeing the issue? I need to see what you have done that may be causing the issue.
alistair316863
HI Jason I have found another site that is currently in development that has the same thing have a look at the home page and you will see the spacing for the H1 and H2 is too big details are attached - Thanks Alistair
I dont see anything wrong with the display of the h1 tags on this page:
pioneer79/
Am i supposed to be looking at a different page?
Please give explicit directions on what I am supposed to be looking at.
